IPTVHoliday.com
anyone know anything about them are they legit is their service good ect ect by mistake I had put in IPTVChannels.com That one has no issues the guide is ok and the service is good. The one with the problem is IPTVHoliday.com sorry for the misstep
well over 2 months now since I purchased them ( IPTV Holiday) I can give some feedback on the service now the TV part works ok but The guide is non existant, I have contacted support twice and both times they say they are working on it. So I would not recommend them at this point if they fix the guide then it would be worth it.
Sad to see but also very common. Many leechers are good at grabbing streams but not epg. Best to always go with recomendations from many others and even then its a gamble.
Hard for me to believe that this provider is on the new good list with no guide for 2 months.
