Are there any good IPTV services that support 6 or more devices simutaneously?
Most I know support 5 connections. But many you can get say two 3 connection subs. You just need to talk to them and see what they can do for you.
BTW we can’t name IPTV suppliers by name in open forum so ppl will have to PM you any suggestions.
Like @Miki said it depends on the service and their options as far as the amount of connections. Just don’t mention any names here please
Any of the ones that I have ever heard of or dealt with will likely offer you (2) Three Connection subs for that scenario (like @miki mentioned). Still cheaper than cable. As the gang mentioned, no names of any services in here please.
Why not just get multiple accounts?
Also, as a reminder, it is SIMULTANEOUS connections. So, you would have to run 6 connections at the same time to use all 6 up. You can put a 1 connection service on 100 TVs, as long as you only play 1 at a time, that is within the allowable use of the one connection service you are paying for. Must be used in the same household, though.
How many TVs are going to be use simultaneously?
If I was going to get 6 connections, I’d subscribe to two or three different services and add the two or three playlists to each device.
Using Tivimate you can put any channel in your All Favorites from all of your services and have ONE master playlist.
Because it is easier to deal with one account.
I have 10 TVs in one room, so yes, I would need them simultaneously.
One account may be easier but the most connections I’ve seen are 5. So 2 subs may be the only option.
I would still ask about 1 sub with 6 connections. I have never seen it advertised, but maybe they can make you a special deal.
or setup a server, get one stream and restream it to as many tv’s you want.
How do you do that?
For 10 tv’s in 1 room ask for the NASA pckg… lol
Maybe he owns a sports bar? lol I feel guilty for having 2 tvs, 2 tablets, a computer and all of our phones in the living room at once.
You can put 9 screens on one TV using Tivimate.
TXRon,
I’m with AJS1, any chance for a tutorial on setting up a server? (For me I’d prefer a Linux based solution.)
Don’t know if a powered hub would be an option for you you can split your connections one to eight ways
Yeah I have 4 connection but what I found out that I did not know if you are recording and watching it counts has 2 connection
