Why can’t I click and use favorites. I downloaded your IPTV Smarts Pro on a new device and it won’t let you “long press ok button” to set favorites now.
We dont own iptv smaters, its also just an iptv player. Just pointing that out, i done use it so im not sure whats going on.
Are you sure you hold the button long enough? Mine is very slow…
Try XCIPTV player from play store it is a very good app much better than smarters.
And tivimate is much better than both. Better option all round.
i did also try Smart IPTV also good choice for me
From my understanding, Their having problems with iptv smarters Pro, it’s not just you, I had the same problem also.
