Iptv smarters pro question
On the IPTV Smaters Pro…if i have a lots of channels and i want to see, for exemple, only the channel in french.
Do they have a option, a trick or someting else to be able to have that…???
Try to have better topic titles, or more descriptive, i changed it.
Tivimate does have a on / off switch for channels to be shown or hidden. When i used smarters didnt like their channel guide and i dont rember their system being that simple to set up favorite channels.
Like AJS1 says…Tivimate is what you want to use…waaaaay more versatile player. :cowboy_hat_face:
A lot more customizable. Smarters doesn’t have, or have I found a way to do anything but add a favorite. No way to organize channels like moving their order. They just add add to the bottom of favorite list. Sure be nice to have more options. Can’t beat TiviMate
Copy that…never cared for that player…when I first got into iptv I used the xciptv player till I found Tivimate.
Tivimate is the best by far. Very customizable and professional looking.
@TP-Dracoo Thank you, for your answer. I take note on that. I will take care of wath you told me. I’m sorry for that…
I’m new here and in that iptv and screaming tv thing and my english is not bad but with you guys it will be better day after day…
Thank you all… for now i’m learning wath is good and wath is not. Why this work with this one and not the other one and he work like that or like that but not like that…lolll…
I take a lots of notes when i read and listen the video on all the stuff you have (my brain hurt) … just joking… it’s that way i learn and like that kind of stuff. It’s the kind of reading and watching i love to do and it’s the only of stuff i read because i hate read some book with nothing to learn or i got no interest of it…
Its all good, just a heads up so we can help you best
Bécuille,
Il serait peut-être préférable d’utiliser Google Translate et de rédiger votre question en français, puis de copier le traduction anglais sur un site Web anglais, comme Troypoint, par exemple.
English Translation -
Becuille,
It might be better to use Google Translate and write your question in French, then copy the English translation to an English website, like Troypoint, for example.
Set up the channels as favorites.
@BECUILLE Use parental controls to lock / unlock sections. There is video how to do it. I will try to find the link and post it here.
