I installed the IPTV Smarters Pro Application but it does not show up in my apps.
Tried to install again and it says App not installed. The package conflicts with an existing package by the same name
First of all…Welcome! If you have a TV service downloaded with its own app, Smarters won’t load because that’s the player most likely being used by that service. Did you check in settings…Apps to see if it was actually downloaded?
Thank you. It is not in my settings apps. I do have another streaming service I use.
Welcome to the community.
Make sure you allow from unknown sources is on amd disable play protect and try again.
Use the rai.
Hey @mike259 good suggestions by Dracoo & 429…not sure where you downloaded from but maybe try another location…if same thing happens then you can eliminate any faulty download issues…may not be the answer but can’t hurt to try. GL2U
Is anyone having issues with Smarters pro. It won’t download anything. I deleted the entire app and re-downloaded it from Troy’s toolbox. Still keeps saying retry .
Is this an issue with the app or a service you are trying to integrate?
@Heinz22 I’d try another one of the free players from the Toolbox with your m3u or xtream sign in data. You’d be able to tell if Smarters pro or the streaming service is the issue.
I’m 90% sure that it’s the streaming service.
The issue is with the app. After I put the code in nothing would download.
Maybe but its been working fine until now
What you are describing is indicating one of two things, and it’s not smarters pro. Either you’re making an error when inputting your user name, PW, etc, OR more likely, your service went offline. And going offline can mean your sub ran out, the service had a technical glitch (happens…mine went out yesterday when the server had an issue with their internet) or the service had to shut down for legal reasons. Or maybe your ISP is blocking the site???
When a service goes offline, whether verified or unverified, it is very or nearly sudden with little or no indication that there is going to be a problem. If the service is offline, then a correct code will not download.
Again, try another player besides Smarters Pro & see what happens. Another way to test is to DM your sign-in details to someone & let he or she test it for you on their set up.
I have another that’s working that’s what make me think its the app. Ill reach out to Amber and see what she says.
The problem was the URL. Once Amber gave me another URL . It worked. Weird because it was working for months.
