šŸ“ŗ IPTV Services Detail
Looks like good value at $70 per year. They claim 100% uptime and no freezing.
I’m trying it. Be careful if you use xtreme codes. They give you an M3U url which is actually the server for Xtreme codes, you then put in your username and password as normal in TiviMate which is all I use.
Let us know how you like it compared to Amber stuff or whatever else you currently have to compare it to.
I’m only seeing an option for 1 connection???
I saw 1 connection on 2 devices :face_with_raised_eyebrow: :thinking:
Will do @GraceWilson. It loaded just fine and has all my locals including PBS. I’ll scope it out and put it through the paces with the Cotton Bowl tonight !!
extreme sure looks like strong for twice the price.
They have multi available. I got three connections for 6 mos. Seems good so far but further analysis to follow. BOWL SEASON ROCKS!!!
Can you share what iptv your using? Thanks!
Does anyone else get blocked from most of these sites because your anti-virus software says ā€œthe website may not be safe?ā€ I’m getting this virtually 100% of the time.
The reason I ask is that I’ve been a Voodoo Streams subscriber for years, but with the changes they’ve had this past year, it has become unreliable, so I’m looking for another alternative. I currently subscribe to Strong via Amber Baby, but need another go-to when that’s not working well. I’m trying to access Lemo or Yeah, but can’t get there because of this virus-blocking issue (on my laptop - but I can see them on my phone).
Also - when I have been able to look up these sites, they don’t list options for # of connections. Can you use these services on several devices at the same time for the same account?
Any helpful thoughts?
@tobasco27 , is there an option in the anti virus settings where you can enter a web address and add it to an allow list….
surfshark you can
right right, but @tobasco27 mentioned anti virus, not VPN, just sayn’….
Depends on your antivirus and where it is…
I use Norton and this happens to me with some Crypto sites…There is a section called Exceptions somewhere and you can paste the URL in to it…Others may use the term Allow List or Whitelist…
Hope this helps…
Yes.They do.
This link is NOT legit for YeahTV. It’s a bogus imposter site. It will take your money and not provide service.
welcome
I have Yeah TV and this is the verified link.
But this is my last year with them because they eliminated adult content.
Curious how long have you had eaglecast and do they have their own player?
Does anyone have experience with Olympus IPTV ??
