You can mention it in this specific thread, but I will respect your decision. FYI google search reveals a couple of possibilities. Regardless, thank you for your response.
A wise decision. Let me help you. Links below are to Forum Rules and Regulations and TROYPOINT to Discontinue & Delete All Paid Unverified IPTV Service Reviews & Tutorials.
This way, you wonāt have rely on what others say is permissible. Also, hinting and telling others to google is not constructive.
Man, talk about deja vu. I did, and have done exactly what you did, to find out exactly what you have. Theyāre all pretty much imposters of one another. You can always tell by looking at the source url as well, not just the US section of channels. The nerve that they have charging what they do. Thatās why itās so easy for them to resurface after they down. I have 2 services I have been using for years that are set up entirely different than from everything else out there. Iām grandfathered in at pricing, and they donāt take any new clients. Iām lucky.
Best & Cheapest IPTV Service = Amber Baby
You are welcome ![]()
How do you install strong. I use an Nvidia Shield. Is it through Tivimate?
The guide I linked to above gives directions. Xtream Codes setup for all IPTV players.
Yes tivimate or any other IPTV app.
Yeah worked great for me until it required a vpn static server, which limits yor vpn locations options. No renewing when subscription is up.
Iām not sure what your mean that a VPN is required. I donāt use one typically .
Iāll be renewing soon, so Iāll if thatās still an issue. I donāt have to use a vpn either so I donāt know whatās that about.
I had a similar error with Yeah and the tech had me doing everything and blaming it in isp. But I finally convinced him do redo my account and itās working perfectly since. He was a stubborn A-hole but in the end my issue was resolved.
The first YeahTV link goes to a site that says you can check out with Pay Pal but at checkout you can only check out with bitcoin. Just saying.
I have no EPG thru Amber. Contacted numerous times and given instructions on how-to fix, but only a select few channels show any lists. The majority only show not available. Any help?
You may want to look into this to supplement your Strong 8K EPG from AmberBaby. I have it and it has greatly enhanced the EPG. Cheap and trial available
I agree. Itās pretty great!!
Respecting the āHe (IPTV unverified) who must not be namedā policy. For the last month, I have had massive buffering using Surfshark and these services. I have tried 30 countries and cities and they are all badāsome worse. I have queried the iptv services, and their response is to change the protocols from Wireguard to open sourceāwhich does nothing. I also have ipVanish and switch back and forth. It is less compromised but deteriorating. I doubt this is just happening to me; I have engaged all the usual buffering fixes with no result. Is this just a ploy from the VPN companies to convince users to buy their own dedicated IP address? Will that be a near-permanent fix. Thoughts?
I think you missed some important info.
I did see that. Nothing named, just asking about VPNs while the thread is active.
Similar experience with Yeah, they blamed my vpn (Surfshark), the only somehow workable solution they offered was using a location with static ip. The problem is limited locations and overloaded servers with subsequent buffering. Before this issue surfaced, Yeah worked great. I have stopped using yeah though I still have several months left and was planning to not renew. Iāll ask them to redo my credentials and see if that solves the issue. Thanks for the tip.
