Is anyone familiar with ittechbasics?
I got the 36hr trial and seems to work pretty good… But if like to install in Kodi TV guide… The administrator said he doesn’t recommend it… And couldn’t suggest another player to input the m3u… Because there are way too many channels and is like to filter the ones I watch to Kodi… If possible…
Or does anyone know a player for this IPTV? Or configuration of the m3u URL that includes password and user… Thanks
Tivimate paid version, one time fee. Best player by far. Smarters pro if you need a second option. Get xtream code if possible.
100% Tivimate premium. Can customize the heck out of the extra channels and organize your favorites.
So ur saying I cannot use the URL with Kodis tv guide?
Or ivue2?
Only reason is I just can’t stand having 2 separate apps…I love Kodi and have it customized,fast and gorgeous looking…lol
No offense to Kodi but Tivimate is a powerhouse and made for exactly what you are trying to do. Kodi can be used for VOD and your Tivimate could be used for Live Channels.
How To Stream IPTV on Kodi with PVR IPTV Simple Client (2022)
Other alternatives include IPTV Smarters Pro, XC IPTV, and Tivimate. All are on the RAI. Troy has install guides on the main site for all three IPTV players. Use the search function and you’ll find what you need.
I’ve had that service for months now, it works well, with tivimate you can manage channels and turn off ones you wouldn’t use.
@Throttlejockey hey, can you shoot me a screenshot of the Tivimate Companion app? I’m on the App Store and I see a bunch of them but not that. Appreciate it.
Looks like is an Android app only, I’ll figure it out; is already installed on my Smart TV
Thanks sir
Really, What are you trying to use Apple? should be an app for that or if you have an android tablet. The companion app is for managing the account so there should be ios support
I was going to use the app off my iPhone to unlock premium but I can do it on the player on my TV
Yes that was my next suggestion, awesome! it works great so take good look around and you can customize it to your liking… If you can mark this Solved that would be great and have a great day. ![]()
I took ur advice… I’ve just been using Kodi for 15 years, and I have it so sleek and fast and organized the way I want… And actually really like their tv guide and channel\group manager… But I can’t use ittech m3u in it… So I set up what u said…
Only thing is their movie\series not nearly as good as ones I have in Kodi…
Also what’s difference between tivimate premium and regular?
TiViMate premium allows you to add multiple playlist and do an unbelievable number of customizations. The free version you can’t do anything much accept add one playlist. $25/US about $32/CDN for a lifetime sub. ![]()
The movies/series isn’t the strength of Tivimate. I use Syncler, Stremio, even Kodi for those. My love of Tivimate (premium) stems from the program guide and the customizations available within it. Free Tivimate is honestly useless, but at least lets you get a little taste of how the app functions.
I just tried to download Tivimate Companion to both my Fire Stick and my Tivo and I wasn’t able to download it from Google or Amazon either one. I had to use my blue stacks and download it to my PC. I have had Tivimate Premium for about a year but needed to clean up my account.
Companion can be put on your phone also, as its only function really is to organize (enable, disable) your 5 devices that use Tivimate Premium.
Hey, when the VPN is on, my fire cube says offline and the orange set up light keeps blinking… When turn off VPN, it’s back online… Any ideas?
Not sure if you’re using ExpressVPN but I had that same problem on my cube constantly I would have to pick a different server. However I’ve never had that happen with buzz x5 using ExpressVPN so not sure but remember how annoying it was. Good luck ![]()
