IPTV in The Crew don't work
I click on IPTV in the Crew, but nothing happens. Anybody else have the same problem?
@albakk35
Its freely maintained and often goes. Click on it and wait for it to load.
https://www.google.com/url?sa=t&source=web&rct=j&url=https://troypoint.com/kodi-iptv/&ved=2ahUKEwjRgP7g5oX4AhWRmo4IHRexCm0QFnoECAYQAQ&usg=AOvVaw2RG2xfgh9ym_AGTLgGD_sN
Thanks. I will try this addon.
Ya I tried iptv in the Mad Titan addon and could never get it to work. I used Troy’s tutorial and wham, it worked.
I just finished watching a channel on USTVGO on The Crew. It worked fine all evening. Are you using Kodi 19.4? I would try updating The Crew. In Kodi 19.4, the addons do not update automatically, you have to update manually.
@albakk35
The Crew IPTV section tested, and works fine.
It could be an update issue. To manually update navigate to: Add-ons> Install from Repositories> Hover over The Crew Repository> Long press on Ok from your remote> Select Update Repo.
Also it could help when changing VPN location.
I will try to update. I never did this before, so hope that will solve the problem. Thanks for all your help.
It worked. Wonderful. Thanks again…:blush::+1:
