Hi, all probably seems a bit overkill but i have 3 iptv services going at the moment ( really good deals ) however i seem to be having trouble with some epg’s some with Tivimate and some with IPTV Smartes, i have tried the all in one m3url and the seperate ones also the xstream codes, but still having trouble with one or the other. I have read that some people have entered upto 40 codes, but i dont have the time or the inclination to do all that. Can anyone tell me of any quick fix as i am sick of seeing " no information available. Thanks as allways. Jimmy.
If they are paid services I would hope the IPTV EPG’s are at least decent? I have 1 paid service and the EPG is really good but am adding more playlists and more EPG’'s and assigning all my EPG’s to every playlist I add. I learned from @Miki and @Powerfader they are on top of the IPTVStuff!
Try this epg. I use it and it seems to have a lot of channels, even some locals.
Also, make sure you assign all your egg urls to every playlist you have! What one is missing, another may have.
Btw, it is a whole lot easier, faster, and accurate to copy and paste these urls rather than typing them!
https://github.com/bitsbb01/m3u8_creator/raw/main/epg/epg_ripper_ALL_SOURCES1.xml.gz
If the epg is maintained by your paid iptv then try contacting them, they will have to adress it.
Hey @Powerfader I have a couple of no info spots & want to see if your epg might fill any of them…do you know if this url works if I turn it into a tinyurl? thnx…
Nope, but you can try.
If you only have a couple of blank spots. Shoot me the stations call sign/letters and I will search my epgs for it.
Thnx…but that’s ok…the occasional ones that don’t show an epg are duplicate channels (ie low bandwidth channel) & my service has been doing some maintenance work on its epg so it might be rectified soon enough. BTW…turned off my other epgs & just ran with a tinyurl I made of the one you posted & you were right…nada.
Thanks Powerfader i will try them. Obviously its the English and American ones im looking for, ( sorry to anyone who thinks im ignorant not learning another language). Just want to know whats on and what time its on. Again thanks everyone.
