Since time change tivimate guide is off by 1 hour,…figured with time change that would happen. My back-up sub is on, but Dozens is behind by 1 hour
Sup stew…
If your tryin to fix it…
You can change the whole epg by doing this…
Settings…
EPG…
EPG sources…
Choose which EPG source u want to change…
Go down to Time offset…
Adjust accordingly…
You can also change each channl separately in a different menu…
Hope this helps… SK
Knew I seen it in the settings sketch, just couldn’t remember where (before coffee). Thanks for the reminder,…got it adjusted till they adjust.
