I use SurfShark
I have 5 devices on my ASUS router. I used VPN Fusion to install Surfshark on the router. I set it to not exclude any devices.
My issue is this: My LG TV with WebOS shows up in the 2nd block down entitled 'Your IP addresses-WebRTC"
Web OS has a version of G-Chrome browser.
It shows only the internal IP addy…192.168.50.xx
I cannot figure out how this is happening. I must be overlooking something obvious
Anyone have any thoughts?
What does the show for your ISP?
Do you have nat enabled in the vpn settings?
Also if it only shows the internal router ip, thats normal. Its not an identifier of you but a router local assignment
NAT is on and yes it is the internal IP.
I just cannot figure out why it shows?
At first I thought it might be the browser but I have tried 2 different ones.
No AJ…it shows the Surf Shark IP.
If it doesn’t show the provider of your ISP should be okay.
