IP Vanish Not Working On Stremio
My IP Vanish works with all my other apps on my firestick 4 except for Stremio.
Let me preface that I pay for Netfix,HBO Max, & Prime. I just created a playlist on Stremio from the services I pay for so I don’t have to constantly go back and forth between apps.
I contacted Ipvanish about 3 months ago and did everything they recommended.
Stremio connects through the VPN for about 5 minutes then gets disconnected.
It worked for awhile and now I am right back where I started from.
I have cleared the Cache, changed the VPN Protocol, uninstalled and reinstalled the app.
Still the same VPN disconnect result.
Does anyone here have any other suggestions I might try or perhaps Stremio is being targeted?
Is possible that settings on my TV or firestick 4 are the culprit? I have been using this for several years with no issues. Thank You For Any Help You Can Provide.
Lauri
I mean if you are using paid apps with stremio and not the torrents you don’t need the vpn. The paid apps are blocking you becuase of the vpn
can anyone help. since i downloaded surfshark, stremio is not working. i have tried different servers and cities. when i click on a program to watch and click on a server, they dont load and go back to the server settings. also this appears at the bottom of the screen. LibrarySyncWithApiPlanned: Failed to fetch: error sending request for url (https://api.stream.io/api/datastoreMeta). Thanks.
