IP Vanish not connecting
Anyone else having issues with IP Vanish not connecting on Fire TV device?
I just reconnected seconds ago with no problems. If you haven’t already, clear ipvanish cache, force close and relaunch. Then try to connect again. If that fails restart your device. I’m assuming you have not done the above.
Hope it helps
Update to the newest version. Or uninstall and reinstall.
I’ve done all of these things with no luck!
Where can I re-install from?
Thank you both for the suggestions. Seems to be working again!!!
Is your vpn back working? If not, you can download IPVanish from the firestick app store. Just click the magnifying glass and search for the name. I’m that sue if its the latest version. I think its the version I’m currently using.
