I did notice it’s faster on openvpn over wireguard even tho wireguard is supposed to be much faster?
I had that the other day, I just logged out and logged in and it corrected itself. But, my error was wireguard error message!!
A lot of which protocol works best is dependent on your ISP, that’s why I always spend at least a half hour, after installing a new VPN app to test every option available including locations, protocols and ports. I run a speedtest after every change and keep a written log. Older person here, so a written record is helpful. This also gives me a record that I can compare VPNs with, but keep in mind even though you may hook up in the same city with different VPNs they may be using different equipment with better/worse specs, so results can vary greatly.
