Installing Orion With Stremio on Mecool KM2 Plus
After yesterdays problem with Real Debrid I was looking for an Add-on for Stremio without using Real Debrid. Orion was the obvious choice but I can’t seem to be able to configure it past the video quality box on my Mecool KM2 Plus. I can’t scroll down or go back, as that takes me back to the beginning of configuring.
I’ve tried numerous times with the Google TV App and with the remote itself, to no avail, so can anybody give me any advice on how I can do this please?
Many thanks🙏🏼
I’ve followed all of that to the letter, several times. On my Mecool box I can’t scroll past the video quality setting box.
Is there a way to force the configuration settings to another browser within Stremio?:thinking:
I think you could have it open in a different browser if one isn’t already set to default. Also if you had a Rii mini i8+ remote/keyboard you could scroll down with that or an airmouse will sometimes allow scrolling.
To get it to scroll with an airmouse, place your arrow inside the area below push and hold OK button and slightly swipe up or down, then release OK button and see if now it will scroll. Good luck
Unfortunately I don’t have either of those😏
I can’t find a setting to see what the default browser is to be able to change the browser.
I’ve just figured out how to scroll past all the options and go to the bottom of the screen by pressing the channel down button and the up a couple of boxes to the install box👍🏻
I’m a bit lost here. You can “enable” or add RD to Stremio but it certainly isn’t necessary. There are lots of Stremio addons that will scrape and supply free streams. The easiest way to accomplish any of this is to set Stremio up on say a phone or computer. Once fully configured, on one device, you simply install Stremio on any other device you want, and then simply log in and all your configuration is automatically applied. This is one of the major advantages of Stremio. It’s cloud based. RealDebrid isn’t necessary, it’s just another reliable source.
Have fun and STREAM ON!!!
Thanks Miki, I’ve just installed the web version, on my Mac and iPad, and enjoying the freedom it gives over the iOS app😃
