How do I install Oath in the latest Diggz Xenon build. When I loaded the build it didn’t come with the Debrid Zone for quick access to rd apps or Oath loaded.
You need to do some searching on here… the oath is no longer supported or working. Its posted and talked about.
I appreciate patron, thank you for your support.
Thanks, that’s too bad. Oath seemed to work well and help keep track of what episodes were watched. Haven’t had the same luck with Venom. May be something I’m not doing correctly.
Venom is also gone. Which is also discused. Id use crew or seren with real debrid, probably your best kodi option of you have real debrid.
