Installed apps on expanded memory Fire stick not upating
Hello, I’ve increase the internal memory on our Fire Stick. The installation all appeared to go well. Installed IPTV Smarters on the Fire Stick and got an error message, this didn’t go well. There was a notification that there was an update and I tried to instill it. An error message said because the app was on external memory the update couldn’t go through. In addition the app itself is not working as it should. The main problem is that the Channels don’t respond properly, stalling when attempting to be watch and having to be worked around to stream. Any suggestions?
Thanks Bob
I would not put your IPTV app on your external storage. Keep that on the main stick with other important apps that you need daily and use heavily.
This is common. You usually have to transfer it back to the device internal memory, update it and then transfer it back to the USB. Any app requiring a lot of CPU cycles is best left on the internal if you run it daily or for a long time. Oh “snap”. You’re a fast typer @AMD237
Thanks for the info.
