Install Weyd on Firestick/Fire TV and Android TV Box (2023)
Also check the Weyd website> dashboard that you havent exceeded the number of devices.
You could also ensure that you are using Weydz scraper. The Weydx scraper is no longer maintained.
(http://bit.ly/weydz)
I’m now getting a message that scaper JASON is missing or corrupt.
Did you change the scraper to the one i sent you. Weydz?
yes I did
I had the same issue when i changed to Weydz. So, i simply uninstalled and reinstalled.
You could simply clear data in app settings and start again. It worked for me.
Did my last suggestion resolve the issue?
Very disappointing not to receive the courtesy of a reply in my attempts to help the OP.
It seems to be the modern way on other forums too from some posters.
yes it did.
thanks
Just wanted to hop on and say that Weyd is temporarily allowing CC for the lifetime subscription until 12/31. I am not into crypto and this was awesome. I also saw that they have added Torbox as an option too. If anyone has that service. Can’t confirm cause I’m still waiting on Torbox to open subscriptions again for myself.
Greetings,
Disguising my IP address is very important to me when streaming. But I noticed WEYD no longer wants to work with the VPN on. As soon as I disconnect the VPN it goes to the home screen. With the VPN on I get a black screen. Any suggestions or what is going on would be helpful. Thanks in advanced
Using ExpressVPN and never had a problem with Weyd.:person_shrugging:
Last week I posted the following comment on the Weyd app: “When selecting a program to load, all it shows are Watchlist options rather than listing links. Not ready for Android 14?”
I’ve since discovered that this was a scraper issue, solved by “remove all scrapers” in settings, then re-adding the scraper “tinyurl.com/weydx”. I also had to log out of Premiumize and log back in to get those links going again.
Weyd status: premium valid. Expires 6/2026. ONN device connected.
When I select anything, All I get is Watchlist: Remove from watch list or Mark as watched.
Please see post by wadebob
“Last week I posted the following comment on the Weyd app: “When selecting a program to load, all it shows are Watchlist options rather than listing links. Not ready for Android 14?”
I’ve since discovered that this was a scraper issue, solved by “remove all scrapers” in settings, then re-adding the scraper “tinyurl.com/weydx”. I also had to log out of Premiumize and log back in to get those links going again.”
Thank you Canonbenny!! I tried first by deleting Scraper Source URL. I re-entered Tiny URL and clicked Refresh Scraper Script. That,did it. I agree on device version 14. I remember when I first setup WEYD a pop-up indicated the app was for an older device. Clicked ok, and installed.
Thanks again
Glad that worked
Will torbox ever supported in weyd without a lifetime subscription?
If not then there no point trying it out for me because I prefer torbox to all the other debrid services
My final post / comment.
Troypoint told everyone in Oct. 2024 .Download WEYD and Premiumize.me.Idid . And it “still” works perfectly. It costs a bit. So does Real-debrid. So until it crashes. And it probably will before my annual subscription to both offer me no streams , just like CinemaHD did 3 days ago. 8 years I’ve been doing this. When one apk crashes. Another one seems to pop up. Good luck to all of us.
My cinema hd still working as normal
Weyd won’t allow me to rematch a series episode to be watch again. I get “ remove show from watchlist/ collection/ history “. I do that, I get “add show to Watchlist”. I went into App and Data Management and cleared all clear Watchlist, watch history, and cleared local tv and movie cache. Then clicked restart app. Any thoughts please.
