Install RTE PLAYER on nvidia pro
I have been trying to install RTE player on my nvidia pro.i have tried downloader and google play store. With no luck. I get not available for this device. Anybody have a work around for this
I’m searching for help as to why my downloader will not load any apps it just says status loading forever!
Try it from the Playstore and seeif it works for you.
Hi thanks very muchfor your reply! I’m so sorry I don’t know what you mean though… playstore?.what is that? (Using firestick). and what do you mean i should search for?
That URL doesn’t seem to work unfortunately.
You are correct. Appears to have been taken down. Tx for letting me know.
Did you have a look at the Google Playstore? The player is there. As far as the App Store the Nvidia Shield is not a FireOS.
