Install Mad Titan Sports Kodi Addon
I think its down. The Loop works, which are the links at the top of the sports section. Also you can look for the sports channel in the section just below “Sports”. And as long as it isnt espn you are looking for you can use TheTVapp addon.
Or as @elginherd said. Streamfire and Sportsfire usually work well too.
Lots of other options. :grin:
Actually it’s up and running. Just tested.
Did you make sure its updated (should be automatic)?
What are you trying to watch? I can try to test it.
Is there an error message?
It worked fine on my phone. When i tried in my onn pro it wasnt working.
Go to mad titan addon and long press to het options. Press information and then versions and reload the addon. Restart kodi and this should work. It worked for me.
Thanks for the replies ,tried what you said but it says no version available
Thanks
If your seeing no versions available when you click on versions in the information page than it means that the repository of that addon is not installed or needs to be updated.
Check to make sure you have the repository installed and updated.
Ok as @Matteos said let try to find the repo.
Go to Addons section. Click below where is says “install from Repo”. Click down until you see Magnetic Repo. Click and select video addons. Select Mad Titan sports v2.0 and install.
It should be there as it comes pre-installed on the build. While you are there install jetproxy as well. Youll be asked to dl it later anyway.
If its not there, download the build again from the wizard. It should keep all of your rd accounts logged in. Just dl over the current build not a fresh install.
Edit. Thought it kept your trakt account but you may need to reauthorize.
So I’m curious, has mad titan changed to a UK format? The epg has lost channels like ESPN and big ten. And has a lot of uk stuff. Just curious
I’m on their Telegram channel a lot and I assumed most are from the UK there. I only watch replay content. If you’re on Telegram, join their channel. It’s super active and informative.
Need the info again
I’m pretty aggravated with mad titan I can’t seem to get rid of the loop peg it is overriding my normal m3u and epg. Then like an idiot I used the wizard and clicked fresh start and boom lost everything on Kodi. Can you use the old mad titan m3u and epg on simple client and not install the mad titan app?
But they dont have many NCAA babll games if any. Looking for an app for ncaa bball games.
Best free one is probably Sportsfire.
Go see the troypoint website to see how to install that.
Look into the Daddylive KODI Addon. I don’t use as I have a paid IPTV service for Live TV but set up a friend on it and it has been working very good for live sports. Do a search here
I recently did a fresh install on my galaxy tab diggz xenon build ,and I got mad titan sports working , I have never been able to get it installed before, So i did a fresh install on my nvidia shield and it wont work same message I always get (Could not connect to repository ) what am I doing wrong
It used to be my favorite. Although it is installed, it won’t pull sources. Time to try the loop.
Daddylive works for me with Surfshark VPN disconnected but I get zippo with the VPN connected.
I watch NFL replays on Mad Titan all the time, there was an add on update YESTERDAY and it’s working perfectly right now as I watch Pitt/Dolphin replay, I’ve never tried live sports. I would smash things as soon as it started buffering live sports.
Well, my Mad Titan Kodi addon just auto updated and this latest version (v2.0.33, I believe) is simply horrible. The user interface (which was always pretty poor) is even worse now, the kodi home screen shortcut doesn’t work, and the live channels are broken.
Sigh…
You shouldn’t be disappointed that Live TV is dicey in KODI addons. It’s been like this for years. The Crew’s live TV was great for about 2-3 years then it sucked. I moved on to a few paid IPTV services and haven’t looked back
