Inexpensive NAS w/disk for Nvidea Shield and
I don’t know why we all use cloud storage but I’m over it. I want a NAS setup with hard disk to work for my network including pictures and files. I also want to be able to record on tivimate thru the shield. I’m assuming i don’t have to integrate plex as the shield can host smb. Any advice welcomed as I’m going to put my entire life on it.
Yes even tho the shield advertises as a plex server it can be used with smb. I set it up with emby in the past and I also know jellyfin works as well. Basically all the shield “plex” function is is smb. Actually it works better as a dvr as you intend than an actual server as its really under-powered for that imho.
I record TiViMate to a usb attached SSD using my Shield Pro. @TXRon is the NAS guru but the shield has the settings to Mount Network Storage and setup, under Settings>Device Preferences>Storage>Mount network storage.
yep Miki thats smb and now Formuler and Buzztv boxes have that as well. Makes it easy to configure. :+1:
Way cool. I need to follow your example and figure out how NAS is different from my “removable” storage. Time for more reading and learning. Tx @TXRon
look at it like this, removable storage is attached to the box where nas is local on the network not actually physically attached.
Aha. But do I need it attached to say a computer or such?
pretty much or if you have a router with a usb you can hook a storage device there and save on the network. In my setup I have a nas running(small pc) and it has my 8tb storage. Doing this all devices in the home can feed off of it. I also host all my iptv subs on the nas and direct them to my devices(players).
Ahhh now I’m getting it and yes my router has a USB plug. So I could have plugged my SSD drive in a usb housing into the Modem and then any device attached to my network could record to it. Now I just need to see how to send recordings or files to it from different devices and I’m guesssing that’s what SMB is for. Can it be done using WiFi?
you can plug a usb into the router if its supported. And yes then you can record from any device in the house to the same location. You can watch programs on any device recorded with other devices. smb is a windows term for file sharing on the local network(basically).
Excellent. Just wondering how each device connects to that storage. This sounds like something a large family household could use. Thanks as always @TXRon.
That’s where a little homework comes in. SMB is easy and hard if not setup correctly. Installing it on an asus router is pretty plain and guides you in the setup. On a nas about the same as nas platforms generally are made for smb and assist with the permissions. You know me and permisssions :joy:…most peoples issues dealing with recording/sharing are permission related. Its not that difficult as I consider myself a novice at all this, ive gone through lotsa trial and error(but its fun). A good starter read is HERE. And remember xplore is your friend dealing with smb because its setup for it.
Oh hell ya. You know me and research. I thrive on learning and I sure appreciate your guidance. I know what you mean about permissions. It’s all about the settings and the research. So now something new to focus on. I’ll save that link for tomorrow and get at it. Be well @TXRon. Have fun and STREAM ON!!!
Im not sure but I think the shield only responds to fat32. And many many nas don’t work well with shield for playback. That’s what I need to find.
The SHIELD supports and will automatically mount drives formatted with the following common filesystems: exFAT (compatible with both Windows and macOS) HFS+ (common for macOS) NTFS (common for Windows) So while it won’t format a drive to NTFS, if one is attached to the Shield Pro it will mount it and you can use it.
I generally use ntfs without issues.
@TXRon , i am coming to you, cuz says, Miki. refered to you as the nas guru. I have set up TV mate to record. On the flash drive, but yeah, would like to to be able to set up recording to my Nas.synology, 3 TB, raid. You mentioned that it’s simple, but can be hard. If done incorrectly, I definitely want to do it correctly. You got, or can you refer me to a detailed tutorial ?
I DM’d @TXRon , hoping he can set me straight on how to. No rush cuz i just now am getting my nas back online. Haven’t been able to access my library on plex since updated plex bought yr. &1/2 ago. & just found out plex is jacking up their yrly. Sub way too much fur me. Probably gonna buy a lifetime Emby or try Jellyfin. Any feelings 1 way or another?
I really can’t help. I never record anything. Ron definately is the one to help out. He’s done the NAS and I’ve seen him helping others. Pretty sure you got the right guy. Keep us updated with your progress please.
Always appreciate ya Miki. Yup, gonna wait on response from em . Was gonna try it on my own , but noticed he said if done incorrectly , can be a mess.
