"I'm Not a Robot" CAPTCHA
Lately I have been getting “I’m Not A Robot” CAPTCHA notifications on my Mac, MacBook Air, and iPhone. I have called Apple and they recommend disconnecting (turning off) the Surfshark VPN. Is there a way to eliminate the “I’m Not A Robot” notification without disconnecting the VPN? Thank everyone in advance.
Leave your vpn and do them. Its an automated reposnce to make sure you are not a click bot. Disconnecting the vpn will not fix it. There isnt a way around this.
you can try changing servers, might work and might not. Its more of a site by site issue. Also blockers can cause this. Example is downloaders javascript.
That too, its merly a crappy attmept at website secuirty. Its annoying and doesn’t do a thing. Almost anything an trigger this not a bot thing.
