Hi, I want to add another addon and I have recently installed the iconic build. I need to get back to the kodi screen but can’t find out how to quit iconic as it auto starts gone through iconic settings and can’t find how to stop auto load. I can quit the application but it shuts down kodi.
When you install a build, that build’s homescreen replaces the standard Kodi homescreen.
Using the Kodi jargon, the default Estuary skin is replaced by build’s skin…though you can probably change the build’s skin.
You can either change your skin back to estuary in the settings of the build or clear data in manage apps and start fresh and just have Kodi and 1 app or 2.
