I installed the Iconic build but would now like to go back to the original Kodi options. I don’t see a way to exit out of Iconic without totally exits out of Kodi also. Thanks.
Welcome, If your trying to get the stock Kodi screen you need to go to settings and skin. Change to Estuary. Or you can clear your data and start fresh.
