I want to drop Spotify for xManager but have a few questions
Before I install this I want to make sure im going the right direction.
  1. Is a VPN required at all times while using the service? I haven’t looked to see if they’re peer to peer.
  2. Once downloaded, do I just log in and cancel my subscription?
  3. Will my Spotify dashboard remain and function after I close my account?
  4. I use my cell phone for everything. Will it work at all times while travelling?
I have IPTV, debrid, syncler+, Smart tub Next, Orion, and full Kodi but not a music service. It just dawned on me that I should have done this long ago but haven’t. Thanks for any input. And if there’s a better alternative out there please let me know.
How to Install xManager on Android for Free Spotify Premium
xManager is a program that will patch Spotify to give you an ad-free version. I guess it is a little confusing when you say that you want to drop Spotify for it. xManager isn’t a music service, it does the patching/cracking of the service, whatever term you want to use.
After installing xmanager and selecting the latest version under stock patch I cannot get the patch to show up to install. I did it when it was first introduced to us, has something changed?
Please let me know if you can help, I want premium back for free.
I don’t know how to get responses from this, so if you have a solution please send it to ***********@gmail.com
Thanks
You probably shouldn’t post your email address. Let someone send you a DM instead.
I just need something for iOS
I’m tailing this post! I’ll take some of what they’re having as well!
Did you have any luck finding something that’ll work on iOS?
I have not found anything yet. Hopefully someone will figure it out.
