Hello Group,
I was wondering if this ONN has malware installed, are they safe to use?
Thanks For your Reply
Only you can prevent forrest fires
No malware unless you put it there. I would consider it very safe being from walmart makes it more so imho. But once the box is open…“only you” controls what happens next.
Aisle 4 Amigo. Very energy conscious with your electric skooter.
Do they still have the blue light special? I try to avoid the place as much as possible.
No idea. I have a hard time getting in. Those old greaters scare me.
Does Mexico have walmarts?
Never mind 2,800 stores
That was the infamous K-Mart with the blue light special.
