I need to change my settings in kodi from Japanese to English. It got changed by accident.h
Thanks,
Bill
  1. Open the application Kodi in your system.
  2. Click on the icon adjustments of the app, that is, the one that you will find on the right in the form of a gear.
  3. Now a screen will open with a menu full of options. You must locate one that says Interface Settings (in some updated versions you can simply call Interface) and click on it. If you have Kodi configured by default in any language other than English, then look for the equivalent to that option or be guided by the option icon that is like a pencil and a crossed ruler like the one in the image.
  4. Go to Regional> Language. From there search the language in which you are trying to set up Kodi.
  5. Click on it to select it and go. It is possible that if you do not have the translation package installed, it will have to be downloaded first, wait for it to be done and that’s it … Now the interface should be in your native language or in the one you have selected.
It’s that simple to change the language of your Kodi …
