I have a question about Real Debrid
If I was to try this service out to see how it works for me would you recommend the 15 day plan or the 30 day plan
either one, you will want to keep it once you set it up…its one of the best tools out there for streamers
@Cooltwou what @TXRon said is absolutely true!:+1: I’ve been using Real-Debrid for over 5 years. I started out with 30 days, then when I found out how fantastic it was I went with 3 month’s plan, now I get the 6 month’s plan​:+1: Whichever plan you decide to choose, you won’t be disappointed !!
Yes Real Debrid is a must. I buy 2 x 6 month plans at a time which keeps me covered for the year. You will get the best steams every time, plus if it was shot in 4K you will get the 4K streams also :slight_smile:
@Cooltwou
I was under the assumption you had it. Honestly get it, makes a huge difference.
Plus that movie you where trying to find is included and works great. Get rd :slight_smile:
Well I got that and went to watch that movie last night and the quality was still not that good and the movie wasn’t in English and that was on Syncler with RD and Cinema HD with RD also
@Cooltwou
I’m really not sure what to tell you. You are using programs with real debrid synced, if you have a subscription it should pull from the server. Everything I have done on kodi stremio syncler weyd works just fine and as all the proper versions.
Well I don’t have the paid version of Syncler because I can’t afford that and I am just telling you how it works on my end for that movie
@Cooltwou
Doesn’t matter, if you have real debrid and update subscription time the free version of syncler shows it, stremio shows it regardless of rd or not kodi with seren.
So the options are there, I don’t know why you are getting these non English or non versions of that movie. I have done searches on everything and have copies. Not to be rude I’m truly trying to help you I just can’t explain why you are not getting what I’m seeing.
Well I don’t know why it is not in English either
Every once in awhile I get a movie that is in Hindi, Punjab or Spanish. The other day it was in Italian. No biggie, I just look for a different source. I have, however, seen in the RD feeds the language it is in so I just pass by those
Over 95% of all streams are in English. Yes, you’ll occasionally get a show in a foreign language but this is pretty rare and may depend on the show.
I have tried source after source for that movie and it is the same thing every time not in English and bad quality
You can use real debrid with a computer in case you didn’t know. Just find a torrent site and maybe you can find the version you are looking for. It’s been my experience that if you can’t find a good quality on a torrent site. Then it doesn’t exist.
Put it on a jump drive or link your pc.
Good luck
I took the 30 day, but i trally like it
