I have a question about apk for Firestick
giphy
Not sure how the browser would help you take anything off the firesticks. So many protected modules and the best you can do is return them to factory.
Totally agree, can’t update the apps I use because of all the pre loaded ones I don’t :face_with_symbols_over_mouth:
I was hoping there was a way, but knew there wasn’t it’s a pain having to go in and clear cache and force stop but it’s worth it to free up space…thanks for bringing this topic up for discussion
you can use a cleaner that will do it for you not sure what is best but a search on here will tell you
I believe Amazon Music is removable
yes it is :+1:
I wish that there were!!!
In the downloader app open Files and delete all the files, That’s usually the problem, These files are no longer needed.
Sorry I have no idea what you are talking about. That is certainly one method of deleting files obtained through the downloader app. But no idea why you’re telling me this…
There is a “Debloat” tool available elsewhere on the net that disables many of what you are inquiring. It doesn’t remove them, it just disables them.
I always delete my files per Troy’s detailed instructions been doing this from the beginning…thanks for your suggestion
For internal use, you will need to format it so that Android will recognize it. There are many YouTube videos on how to do this.
