đŸ”„ Huge Update for Fire TV Launcher Manager (First Look)
I heard the new Amazon OS update won’t let firestick users use certain iptv’s. Could this be true? My provider told us we’d have to buy Nvidia shield or shield.
@TROYPOINT Regarding updates on router. I put those 3 URL’s into the URL filter. My test was to use a 4k firestick and selected the ‘Check for updates’ and comes back with ‘Your Fire Tv is up to date’. Is there possibly more URL’s that need to be blocked? Only using 4K stick as I have already put hack on 2 cubes and 4k max.
Hello, many times the way you input the URL into your router matters. In my Asus router I had to only add the url without the http:// as it I added that it didn’t work. Other router brands, it’s vice versa and you must input the http:// with the URL.
Will give it a try, thanks!
I had to put www. before name, it wouldn’t accept http://. It took a while before it started working. Fire Stick 4k getting ‘Update error’ now. :grinning_face:
Ordered 4K max on Amazon and received this morning. Was able to get the hack installed using your Block Amazon Updates on Router video (using www. instead of http://) . I was unable to use the android phone method, wouldn’t connect. After I installed hack, I was able to factory reset and reinstall the hack. I noticed that Amazon Prime doesn’t work any more as the app needs an update from Amazon. Thank you @TROYPOINT!!
Happy Anniversary @bsr92336 :+1: :birthday_cake: :confetti_ball: :birthday_cake: :clinking_beer_mugs: :turkey: :fork_and_knife_with_plate: :tada: :firecracker:
Does this mean it did not work on my end? I blocked updates and installed Projectivy and LM, but when I select “Go” in FireTV Toolbox it shows as connected while the launcher still will not open. Projectivy launches without any issue, but the actual launcher will not load.
