Yes there is, but each one generates a seperate playlist. I add all and just deselect the countries I don’t want. This gives me just one playlist that I use instead of constantly closing and opening playlists. Then I choose the channels I want to add to my groups I’ve created. I just find it more efficient. Just a fussy old man. Btw tx for the .html info. That’s cool.
Sure. Everybody should do it however they like it. I only use the specific US list. But we have people here from all over the world which will of course not want that one.
Oh I absolutely agree with you. Like you, I enjoy giving members all the options available to them. We all do things a tad differently and that’s a huge part of this hobby. One thing for sure, I enjoy your posts, you have more tech knowledge, than I do, and look at things from a different point of view I hadn’t considered, like the html info. Tx.
We all have different things to share. I wouldn’t say one of us has more tech knowledge than the other. We just share what we know or what we find. This info may vary from one day to the next as my memory is starting to fade a bit. I have enjoyed your posts and find you to be a treasure trove of information on various topics.
My Samsung smart tv older version sensors search for site like .RSBN,TRUTH SOCIAL,RUMBLE.LOCALS…FRANK SPEECH…ALSO SENSORED YouTube …
Hi, entered the M3U code **https://i.mjh.nz/SamsungTVPlus/all.m3u8**into tivimate and it will no process. Tried it in SmartersPro and the same issue. Can’t figure it out. Any help would be appreciated.
Working for me but not the address I use. Here is the one I use for US channels. Should be the same if you change us to all but don’t quote me on that.
https://tinyurl.com/multiservice21?region=us&service=SamsungTVPlus
Thank you very much. ALL does work. All Good.
I must be doing something wrong cant get any to work
Whatever I do it says url invalid
cant get any of these to work
What app are you trying to enter the playlist in? I use TiViMate.
Tivimate
ok I deleted tivimate and redownloaded it and now got it to work thanks millions!
I had it on my TiviMate as M3u8 but I thought they put a stop to it on anything other than a Samsung tv? Can I reinstall it on TiviMate and it’ll work?
Edit: so I did what I should have done in the first place and entered the url. It works. I get Ask This Old House again. Thanks Miki.
It said error for me the first time. Go back and closely look at exactly what you entered and then check again. I had a space that had to be removed. Also sometimes it will autocorrect to lower case which you just need to change back to upper case manually.
