Ok thanks jsrfrench will give it a try
This is the info Iāve been hoping for. Is there a list of the 78 processes I should stop? FYI I didnāt use the debloat tool to stop the updates but used FireOS Update Blocker. I did use ESFileExplorer but on my left panel āappā was down the list. Returning the Amazon crap to factory settings rescued a good amount of space. Thank you.
@Miki
Just reset my stick to factory settings last night, after loading back the appās I use and debloating. Gained a total of 3 and change of available space. Today, streaming football games and movies later, so far zero buffering. I too would like the list of 78 to turn off.
The list is totally dependent upon whether you watch Prime Video, watch IMDB which is attached to Prime, use the News, TV Guide, have a usb drive attached, have other apps like A&R, History Channel, Lifetime, Use Alexa, & such.
Easier to give you a running list of mine & I watch both Prime & IMBD plus never use Alexa.
No = No checkmark - Yes = a checkmark
1st 5 no
Next 11 yes
Next 3 no
next 3 yes
(live TV Guide) no
vizzini breaks alexa yes
documentsui no
the next 27 yes
franktvinput no
next 7 yes
next 2 no
next 2 yes
sharingservice client proxy no
next 6 yes
next 7 no - all have a .tv
The final 11 yes
This is how mine is set up. If you do not watch Prime or IMBD then put a checkmark next to all those & the others 7 which have a .TV in the description.
Now important - after you click the arrow top right & the program runs thru closing the packages - to get out of the program the proper way is to click on the X inside the white circle.
Happy Streaming - hope this helps & remember 2 things:
1- Update every 6 months or after you hear a big amazon update happened.
2- Rerun the Debloater after the update.
***I also check the Debloater ever month or so since my Trophy Wife will open a program or something which will remove the checkmark. Just like she didnāt marry me for my looks, I didnāt marry her for her brains & she is a real blonde to da bone but a lot of fun to be around.
I just been debloating everythingā¦
& rebloating when I use scamazon
