How to Use Real-Debrid on Kodi & APKs
I’ve been using Alldebrid for over a year. Switched from RD after getting logged out multiple times for multiple IP streaming(wasn’t on purpose.)
I notice no difference in available streams from RD. It’s monthly @ $2.99, and auto renews until you cancel.
As others have said, they are also in France so they may be next.
Always IPTV with VOD for backup :wink:
Troy sent out a letter with Premiumize and All Debrid being to options along with the Live streaming apps that run on their own without a debrid.
Premiumize… I’m using it for Syncler, WEYD, Stremio and Kodi. It’s working great. Real-Debrid is totally Dead. Nothing was working when I uninstalled it.
Yes same here. Now I did sign up for Alldebride free trial. My question is it doesn’t work with Umbrella. Is this because Umbrella was set up for RD? Is there an alternative addon? All the sources show RD even tho i unauth it. Maybe a fresh install?
Just installed Stremio per Troypoint … RD seems to work here…using VPN precaution anyways
Worked a treat with Fenlite on Kodi!
Thanks a lot for this!!
Cheers🍻
Hey guys im gonna try a punt with torbox its $2.1(black friday deal) a month with 3 connections, which can be used at different locations.
They have a stremio addon with easy setup, and it works with pov addon in kodi. Im not sure what other kodi addons.
Located in South Africa
Edit
I went for the standard package in the end $39.66 / £33.09 for a yearly sub. Its the 5 connection plan.
They are having a big influx of rd users signing up so are getting new servers on Monday lol.
Ive installed AD on my Umbrella but it took a little while from registering with AD for the links to come through. I had the same issue with RD still pulling links even though I had unauthorised it. Turns out Umbrella has a provider cache. In the tools, there is an option to clear that, once done AD links came through.
i just installed cinema & I can watch my favorite series without torrents.
Alldebrid costs way less than “Premium:::” & there’s a free trial for a few days. Has anybody tried using it as an alternative? Thankful for any info
After reading the threads and all your thoughts, I was all set to jump to another debrid provider this morning not being able to get anything to watch in Kodi… I have the Crew on my Onn box for tv, use a vpn and only stream a couple dozen tv shows using trakt.
I have been getting a lot of random “no stream available” errors for a few weeks now, and noticed the last couple days could only get 2 random links to work. Well this morning i signed up for the free trial at all debird and got the same links as RD, but none of them worked either… i tried using Kodi on my laptop with the new alldebrid, no streams avail there.
I figured it could be a kodi problem. I read an article that walked me thru a bunch of “fixes” to “no stream avail”. the first one seemed to work for now…
https://vpnpro.com/guides-and-tutorials/how-to-fix-kodi-no-stream-available/
Number 4 -Clear Kodi providers and caches - worked for me
(thanks to everyone who posts, im still new and appreciate the time you all give to help!)
I logged in to my rd and contacted them and asked for refund for my 3 months due to them going down and they immediately refunded me. Already back at bank.
Thanks TP…
I was asking about how to save a link in RD cloud using Umbrella.
Here is the link to get torbox and to set it up. Enjoy.
troy has listed alternatives on here just search
Yep already read Troys alternatives, I asked a specific question in case anyone knew off hand but never mind.
Both should absolutely work with Umbrella. Just go into tools > umbrella addon settings > accounts (Debrid) and you’ll see where to authorize them.
Great luck @T83 …Im paid till April and have passed the 14 day window so i will hang as long as i can…Im sure change is on the horizon so i will keep reading here!
@Lynnski i did too but asked them since your shutting it down will we get a refund. They answered within the hour. Did it in help contact us won’t hurt to try
Good analogy
