How To Use Kodi - Detailed Beginners Guide
Originally published at: How To Use Kodi in 2025 - Detailed Beginners Guide
This in-depth tutorial will show you How To Use Kodi in 2025 for viewing movies, TV shows, and more on any streaming device. You have probably heard of Kodi but may be wondering exactly how you can benefit from it. This detailed guide will provide you with everything you need to know about how to…
How do I stop/end a video on KODI?
Don’t know what device your talking about but if it’s on your TV click the okay button on your remote which will pop-up a display then scroll to the square and click ok on the remote again.
Key mapper Kodi addon is great for mapping buttons while using Kodi.
I have back button mapped to stop content.
Press start button on remote tap square button
Hi all. I have some dislikes about using Kodi. Actually, it may be more about the add-on than Kodi, but all the add-ons seem to share some of these issues. If you know any resolutions, I’ll be thankful. I’ll limit this to three issue and call this thread “part 1”. I use the umbrella add-on, for reference.
  1. When selecting a source from the list of a movie/TV show I want to watch:
    a) there are so many abbreviations in the title/source description. Is there a decoder ring for this?
    b) How can I tell if the audible language is English? There are so many sources in another language, I spend time starting the stream then ending it because it isn’t in English.
  2. Is there any way to incorporate the voice button on the fire stick remote to say the movie/tv show when performing the search function. using the virtual keyboard with up/down/left/right arrows gets old real fast.
  3. For some reason, when doing a title search or using the “popular this week”/day/whatever, there seems to be an unreasonable amount of Asian cartoons. I don’t know why.
thank you!
By the way, I just may name my next pet Peeve.
For the audio, many of the links are available in two or more languages.
To select an English track, hit your ‘ok’ aka the center round button after selecting a link, go to the gear icon in the lower right corner, selecting Audio settings, scroll down to the fifth selection “Audio streams” and select your language.
Jayhawk has the best Kodi tutorial ever, “Kodi Start2Finish” available here under the Kodi category. If you go through the set up with that, at least some of annoyances will be addressed.
I would assume, most likely the Asian cartoons are the most popular choices for that particular week/day/whatever. Especially since youngsters are on summer break.
I kinda understand your issues but I look at it this way. At the risk of sounding like a smarty-pants, how much are you paying to watch anything in Kodi? What service offers so much to watch, 24/7/365, and without ads? And for what Kodi costs? I feel that some annoyances are justified for how much I paid for it.
Been using KODI for close to 10 years. I never have done a search within KODI. Get yourself a Trakt TV account. It is cloud based and integrates very well with KODI. when I hear about a show/movie that might be interesting I add it directly to my Trakt account and next time I go into KODI it is there in My Movies/My Shows
In Kodi set player English. In umbrella click on English only. Says not 100 percent. Most 1080 links if not English will say abbreviate language that’ll type the subs but I got to be honest Kodi is awesome!! I use APK s just don’t compare. POV is awesome if not better than umbrella
In answer to your language problem, while watching the show, I can usually access the audio settings and select the correct language. There are usually two or three to choose from. When doing the title search, what addon are you using? I use FEN, Umbrella, Seren, and the crew. I’ve never had those issues. Try some other addons.
There is a way to choose English as the default within the Kodi settings: Settings/Player/Language/English. If this isn’t clear, Google is your friend.
For a voice search, long press the OK button in the search bar within the addon. A “speech to text” prompt will appear.
Not every device supports voice search within Kodi, even if the physical device natively supports it on the OS. For example, Amazon devices won’t work with voice search in Kodi, but the Nvidia Shield will.
Anyway, I hope the OP watched my video that was linked above. Answers a lot of questions. And as far as all the abbreviations, you can use the advanced filters within Umbrella to narrow them down and put what you want at the top. For example, you can prioritize streams with Dolby Vision at the top of the list. You can filter out SD streams unless there are no HD streams available. Just have to play around in the settings to figure stuff out. Takes some time.
Thanks for this. I knew Trakit was supposed to be more convenient than I was experiencing. I never thought to look under My Movies/Shows. :upside_down_face:
