How to Update Kodi on Firestick/Fire TV
This quick tutorial will show you How to Update Kodi on Firestick in 2022.
The same process will also work on the Fire TV, Fire TV Cube, and Fire TV Televisions. If you have any type of Fire TV or Fire TV Stick, this guide is for you!
if i update my kodi on my firestick, what happens to the addons i already downloaded to it? do they get deleted, have to download all over again?
apps should still be there i have done it a few times with no probs
Kodi 21.3 is officially released. I’ve updated all mine including one with Aeon Nox skin and haven’t encountered any problems so far.
Hi Troy, I have been trying to upgrade kodi on firestick to version 21.3. On Tropoint toolbox I scroll down to kodi 21.3 but there is no download box. When i click on the kodi 21.3, 32 bit, I just get a box saying Status and Connecting but nothing happens. What am I doing wrong? Garethw7
Hi there, did you follow our guide here? How to Update Kodi on Firestick July 2026 (Latest Version)
I see the links working fine on my end? If you were connected to a VPN try disconnecting when updating Kodi and then connect back after.
Are you using any adblockers? If so turn them off and try again
Followed latest version but still not connecting. Tried with vpn off but could not get into troypoint toolbox then. No addblockers installed.
Interesting. See if this helps at all - Downloader App Not Working? How to Fix Common Problems
