How to turn off subtitles on cinema
Hoping for some help. I got a perfect stream on cinema for the Movie Barbie. The problem is it keeps showing Korean subtitles. I clicked on upper right corner icon that says Subtitles and it opens with the heading ENGLISH and under it are 3-4 noted feeds with information that is confusing. Regardless to which one I click on the subtitles will not go away. What am I doing wrong?
Thanks
zmon47
you cant i think there embedded
Thanks pirate77. That makes sense. Guessing the same thing should happen if I use The Crew too?
yes i saw that the other day really good copy apart from sub but dosent interfere much just annoying
