Originally published at: How to Reset Android TV Box & Increase Perfomance (Fastest Method)
This guide will teach you how to reset Android TV Box. Resetting your Android TV Box will return the device to the same state it was in when you first purchased it. When you do this, it will erase all of the applications that you have installed. You can think of this as a fresh…
