Originally published at: https://troypoint.com/install-mouse-toggle-fire-tv/
The following tutorial will show you how to install Mouse Toggle for Firestick, Fire TV Cube, and Fire TV systems. Mouse Toggle for Firestick is an easy-to-use application that works as a Mouse to navigate apps that aren’t compatible with the Fire TV Interface. If you sideload applications onto your Firestick or Fire TV device,…
Hi All, For whatever reason I was UNABLE TO install the “mouse toggle” on my Firestick 4 Max … so “I installed a cordless mouse using an adapter instead & it works GREAT”
This is the adapter I used: https://www.amazon.com/Ethernet-Adapter-Compatible-Chromecast-Internet/dp/B078MNW25Q?ref_=ast_sto_dp&th=1
I simply put the USB for the cordless mouse into one of the slots on the adapter and viola … I have a workable mouse!!
You’ll also find it much easier if you used a mini keyboard/mouse/trackpad as then you not only have a top knotch easy to use mouse but a keyboard for entering txt when adding say playlists or filling out forms or even doing searches.
Thanks Miki!!
Have an awesome day!!
Blessings!!
Where can I download the app?
