Originally published at: 30 Best Kodi Builds | November 2024 (New Builds Added Daily)
The following guide shows you how to install the USA Build on the latest version of Kodi. “USA” is a popular Kodi build from the Doomazday Repository that was recently updated and now works great again on version 21 Omega! This build comes pre-installed with quality video add-ons for watching on-demand movies, TV shows, live channels,…
I installed the USA build on Kodi, on my onn 4K Pro Streaming Device, have a 65” screen on tv. For some reason the picture is bigger than the screen and I am not sure how to fix this. Also since installing the USA Build I can no longer access the Kodi I had is there anyway that I can find the shows I had in favorites? Is ther a video or anything on how to use this build, I need to know how to save shows. Thank you
The overly large screen I have always fixed by finding the screen scaling or magnification settings on my devices. Should be in the Audi/video section under the video section specifically. May have to click around to find exactly where as just about every device does it slightly differently, and gives the setting a different name. Now some do it in the TV settings but I have always used the device settings myself.
When you install a new Build it wipes out anything you previously had in your case your Favorites. 2 Ways to solve this. 1. IMO using favorites sucks because exactly what happened to you. anytime you update or install a new build they are wiped out. I would recommend using Trakt TV which is cloud based so all your shows/movies will always be on any device you use. It’s free and integrates with KODI (Do a search here lots of info on Trakt). 2. If you still want to use Favorites download the KODI 21.2 Fork from Troy’s Toolbox then you can run multiple KODI Builds and keep your favorites on your main Build
