Free and Good is hard to find. When you do find it (think USTV Go) the internet police move quickly to shut it down.
Too true!
Just downloaded latest version of uk Turks 1.1.3 now in settings can’t change player.any help would be great.thanks
in settings go to player settings then change to the players you have loaded thats in version 1.1.2 not sure about your version i didnt update mine i have add free version
From the original Troypoint installation post:
“While using an external video player is usually a great way to reduce buffering, ads, and more, it seems that integration within UK Turks does not work properly.”
“Even though you are provided with the options listed above, these cannot be selected for use.”
“After choosing MX Player or VLC Player, you are prompted to install via the Amazon App Store. Even if you click Continue, the installation will not work”.
yes thats correct just checked it reverts back to turks player ty
Greetings,
went to the turk official website via downloader and when it tries to install Google Protector blocks it saying this app is fake and harmful … this is on my shield.
any clue has to why ?
Cheers
turn off google play protect
Yeah I’m wondering why other apps don’t give me that warning when I install them. Was just caution on this app that it main contain malware
i am having the same problem it’s keeping spinning nothing is loading and will not show any listing of any movies etc keep showing close and next keep spinning
Same here there prob updating
Anybody else having problems with uk Turks not working
My uk turks isnt working now either. Wont load nothing. Un-installed and reinstalled handfull of times. Still nothing.
same here in uk
Anyone know what’s going on with UK TURKS
Hetzner has become unreliable seems they have turned on third party providers because all the third party apps and services using their software are having serious issues right now so everyone is pivoting for another software provider
Just to let everybody know uk Turks is back version 1.1.4 its working fine in the uk
Does app required account registration to use? I’m in the US.
dont think any registration required
App I was going to download showed 6 VirusTotal warning. Did you scan app and it was clean? If so, where did you download from?
