How To Install Strix APK on Firestick, Fire TV, and Android TV Box
Originally published at: Install Strix APK on Firestick/Fire TV/Android TV Box
This following step-by-step guide will provide you with installation instructions for Strix APK on Firestick, Fire TV, and Android TV Box. Strix is a new VOD streaming application for Movies, TV Shows, live TV channels, sports, and adult content. It is currently pulling in tons of awesome sources and streaming fast, especially for those using…
strix not working on shield
not on google app store
Will not sync with real debrid tried the install with TPapp and Amazon download. Shows strix as device in real debrid but never comes back in app as confirmed or any RD links. Sometime real debrid would come back client device ID invalid. Any thoughts? :thinking:
I had similar issues getting real debrid to work, kept getting invalid device message. On my 7th attempt, I got the device recognized message. I am now getting real debrid links.
I finally got device recognized this morning but as far as I can tell RealDebrid system is still down as cannot connect to links though any apps ie: seren, the crew, cinema hd , strix or any other apps .
RealDebrid finally got fixed but with this app there are NO 4K LINKS which is a deal breaker for me as to many other good apps with 4K I will uninstall this.
NO 4K
Not impressed with Strix at all, looks like a reboot of Live Lounge. Too many low resolution links, many much better apk’s out there
Mine works great with real debrid im using an android box
Hello @rumnutz you can install it through Downnloader app on the Shield with the shortcut troypoint.com/strix
My problem with STRIX is that they want you to pay using bit coins or lite coins. I have no knowledge of their value. Then they have this system to convert it to dollars that I have no idea about. With this system, I am out. I am still searching for a S4U replacement. Any ideas???
Hello @rboswell79 I started this thread about Best IPTV services which should help - Best IPTV Services
You have to used the Downloader as he shows above.
