@TP-Ryan I’m sure you know best, however, I have downloaded and looked briefly at both StreamVault IPTV and StreamVault. They appear to be two different and distinct apps. They do two different streaming functions, in my opinion.
To quote Yogi Berra, ‘they’re the same, but different’
I would refer to the StreamVault in our TROYPOINT Toolbox - TROYPOINT Toolbox
What to TheTvApp m3u link info that was on troypoint I can’t find it
Ryan, I did download the StreamVault apk from Troy’s toolbox, it’s a nice looking IPTV Player and is included and identified as such.
I also downloaded the SteamVault apk as shown in the video I attached.
They are Two Different apps with similar names.
To bury this app here deprives insiders of additional education, unless that was your purpose. If not: 75726 or docsquiffy.com
It’s just information some insiders will find interesting & educational.
Tried using and watching, i didn’t incur any major issues. However, I’m a big fan of recording and I don’t think it can be done. I’m using an Onn 4k pro, I can’t use an external drive or internal storage, and if there is a way to use SMB i can’t find it. Doesn’t seem to be any choices for Permissions, so, that could be a problem. I might try it on a Firestick 4k 2nd gen and see how it is there. Also, it was too cumbersome to hide all the foreign channels, you have to do it one by one unlike Tivimate.
Thanks for sharing @BigDave I just tested this other ‘StreamVault’ app and it appears to be a Stremio clone with some pre-installed add-ons. I’d suggest not using this and I’ll make a note in our StreamVault IPTV tutorial
Thanks for letting us know and keep us posted on how this works on a Firestick. Still some kinks with StreamVault as it’s a brand new IPTV player but very promising!
Am I missing something here, how is it free if you need a paid live TV service?
Yup you are missing something. It says it’s a “Free Player” and it is. No Cost to install and you can add any number of FREE m3u playlists and EPGs if you choose to go that route. Yes we all know that a paid subscription is certainly the way to go, and provides a more enjoyable experience, but that doesn’t change the fact that the player itself is free.
Is there a downloader code for the new 1.0.8 version?
Actually the one in Troy’s Toolbox
is 1.0.9
250931 <<<<<that’s to Troys Toolbox
I am also using this on my android phone. It works great but Is there a way to display over other apps on this one? I would like for it to play while I am on the phone or using it if possible
I think you are getting confused regarding terms. This is a free IPTV Player (app) for IPTV. It isn’t a free IPTV service. You can think of this like TiviMate, IPTV Smarters, Sparkle TV, etc.
I installed it on my Shield Pro. I have two services, one for live tv and another for VOD. I can get either one to work but not both. I repeated installs several times to no avail. I have already paid the lifetime subscription for Tivimate and TiviMax plus, I use UHF on my iPhone/Mac/iPad which works fine for me.
Thanks Miki!
Following up after trying to use Streamvault on my FIrestick 4k 2nd gen. I had a similar issue when trying to record. I clicked on Record Folder setup and it kicked me out to my home page, otherwise it worked the same as the Onn TV 4k pro. In all other respects, I think it performed well, just can’t record.
Can someone point me in the direction to find information on how to do a couple of things with this new player?
How do you rearrange / change the order of channels in the EPG / favorites?
How to hide select categories that are listed in EPG section?
Thank you
I had my main IPTV provider installed and it worked great! After trying to install a test from Amber Baby, it wouldn’t load and it locked my original provider up. Test worked well on XCIPTV. has any one else had an issue with two providers on this app?
You can? What are some free M3u playlists and EPGs?
