How to Install Prominance Build on Kodi (Firestick & Android)
Originally published at: How to Install Prominance Build on Kodi (Firestick & Android)
This tutorial shows you how to install the Prominance Build on the latest version of Kodi. “Prominance” is a newer build from the Doomzday Repository that surprised us and works great! We’ve already added this to our best builds list. The Prominance build comes loaded with quality add-ons for watching movies, TV series, live channels,…
How do I uninstall the Prominence build? I can’t access Umbrella, The Crew, and Asgard. It goes straight to Prominence when I load Kodi. I don’t like the interface and I want the Crew and Umbrella back.
@MarkxG gave you instructions in another thread.
Can’t find the thread. I’m having the same problem
I’m having the same problem. Worked just fine yesterday, today I can’t use any other builds and it won’t let me escape.
Read the thread I posted. Looks like you’ll have to start fresh.
OK, thanks
Hi Miki, I can’t find your thread either. Can you direct me to the thread getting rid of Prominence or re-installing Umbrella?
It’s 4 posts above yours. Click that and go to the bottom of the thread.
Beware! Prominance is a nightmare on a Firestick! It takes over Kodi and wipes out everything that you had set up. DO NOT INSTALL.
Well you did install a build. That’s what they do.
Sounds like it’s working great! When you install a KODI Build over what you had it wipes out your previous instance of KODI. If you want to keep both go into Troy’s Toolbox and download the KODI Fork then install the Build. That will allow you to keep both instances of KODI
