Do you remember the name?
Mslea, it is this one. Amazon.com
I had issues with the first one I got since it wouldnât pair with my Shield Pro. I returned and got another one which paired immediately. I like it because it has the same basic button layout as the Fire remotes.
I moved this remote from the Shield since, for some strange reason my Alexa Pro remote started working on my Shield Pro. So far the only issues I have with it with the ONN box is that when trying to do a search on Smarttube, it wonât let me type anything in. The air mouse works but I canât turn off the arrow pointer. I havenât tried the voice search function yet.
Followed instructions and it will not enable
In order to work
I have the Onn plus
Any help would be appreciated
Hello, the new Android TV 14 makes this not work. I show how to do this with TVQuickActions instead in the following video.
This should work on any Android TV device running 14.
I must be missing something Thanks. I followed instructions per the video but cant get any apps to enable Qickaction add to the list
My onn plus will not allow me to get pass to enable
I followed step by step tried several launchers
Even the sideloader but it says i am a developer
I am stumped
