How to Install Meteor Stremio Addon (Debrid & Torrent Sources)
Originally published at: How to Install Meteor Stremio Addon (Debrid & Torrent Sources)
In this guide, you will learn How to Install the Meteor Stremio Addon with our step by step tutorial that provides screenshots and more. Meteor is an On Demand Stremio Addon that serves up VOD such as Shows, Films, and Anime that play in high definition. It can be configured with just about any Debrid…
Troy, another great tool. You’re awesome!
I notice under the heading What We Don’t Like:
Less complicated than others - for me that’s a plus lol
Minor Bugs - such as?
Ad always thanx for sharing
This works well and easy setup. Only issue it doesn’t find Cam’s, Screeners, and telesync’s that are still in the theatres. I couldn’t find filter setting for that.
I opened the site and went through the full step by step config and then installed it into Stremio. I spent 15 minutes testing this out and deleted it. It interfered with both my Duck Streams and TorBox. Both services began to be very slow loading and found way less sources than usual as well as lesser quality. After I deleted it both Duck and TorBox were back to finding 2160, 4K and HDR once again. Could not find a reason for this. Tested on the same Movie title each time as well as after I removed it, no server changes either.
Got stuck at the “Install” button after following all of the setup instructions to that point on my PC. After pressing “Install” I could see the Stremio box, but when I clicked on the box nothing happened. Any suggestions?
Do you get this popup after hitting install?
It did not show. Wonder if I have a pop up blocker problem?
If it does, is that the last step? Or is there more to follow?
Probably a popup blocker issue. Once you get the popup to work , you select Install to Stremio, it will open Stremio app on Phone or PC and ask if you want to install the Meteor addon.
