Thatās not true. It has nothing to do with TiviMate. Some IPTV services donāt allow VPNs or they block some VPN servers.
Try connecting to different VPN servers until you find one that works then stick with that one moving forward.
Also I found one iptv that was being blocked by IP DNS and I had to use a different DNS service in order for the playlist to work.
If you mess up and press the wrong player and always, just go back into the settings, select default player. I then go and start a feed. After it starts I go back into settings again and select external player. When you go to play something you should get the list to pick a player again.
Has anyone else had sound issues while using Just player or MX Pro. I use my stereo for sound. When I use these two players I am not able to use the volume button on the remote. When I go to volume 1, it is full volume or 0 no volume. The levels do not work. Using Exo player the volume works fine.
Thanks, Iāll try that - beats uninstalling and reinstalling!
