Originally published at: https://troypoint.com/hawk-kodi-addon/
Learn how to Install Hawk Kodi Addon and watch your favorite Shows and Films with our instructional guide below. We have easy to follow steps that make downloading and using a breeze! Hawk is a newer choice for Kodi users who prefer addons over builds and is considered a premier option as it requires a…
I’ve been using the Hawk addon from the Southpaw repository for awhile now and really like it for its speed. I got another Onn 4K Pro and wanted to set it up with Kodi and Hawk like my other Onn boxes. Using this URL https://southpawlefty2468rocky.com/repo I have not been able to access the zip file to add this as a source. As such, I cannot install Hawk. Is it no longer available or is it located elsewhere? Is there a way to transfer that zip file from one Onn box to another on the same network? Thanks for any useful suggestions.
That address don’t work anymore.
Can Hawk be found at another repository? Or, barring that, is there a way to transfer that zip file from one Onn box to another Onn box on the same network?
Hello, I just took the zip file and manually loaded it into Kodi. I got the repo installed but when I try to go into repo to install addons I get the following error. So, even if you get it installed, it’s still not working. It appears that there is a problem with the developers security certificate and that may be the problem.
