How to Install GHD Sports Pro on Firestick & Android TV
Originally published at: How to Install GHD Sports Pro on Firestick & Android TV
The following guide shows how to install GHD Sports Pro on Firestick, Android TV, and other devices. GHD Sports is a streaming app that provides hundreds of free live sports streams and channels across a variety of categories. In addition to live sports links, users will also find over 1,000 channels in all categories outside of…
@TROYPOINT I’d like you to send me a message so I can message you please
The dl code appears not to be correct, tried from two devices, with and with out ad blocking DNS. Always returns 404 error.
Same here. 404 Not Found.
He has 2 Downloader codes. I got it to install with the 2155390 code. Haven’t tested anything out yet
Thanks @MarkxG , that works, the apps a bit clumsy but it seems to work, for USA, go to channels, check out the IPTV catagory.
I’d recommend a mouse but I gotta say, I’ve looked at a lot of these kind of apps and this offers more channels than I’ve ever seen.
Or dowload the apk from his website and install it
The code didn’t work. I tried several times. It tried to redirect and displayed error 404.
Did you try what @MarkxG said. Just a few posts up from this one.
Swilly Installed with 2155390 but when attempting access always get network error check your internet connection.
Something on your end my friend, I just tried the dl code, worked as expected.
I have been using GHD for a couple of weeks now and I find it is brilliant.
Getting ‘404’ not found when following Troy’s description of how to install it in Downloader. Anyone else?
Same here, would not work.
I used same code that @swilly used and it works perfectly on firestick
2155390 doesn’t work either.
Strange loaded it this morning worked fine maybe you have another problem
got it to download installed but get the “network error check your internet connection”, vpn on usa
maybe try with vpn off
