How to Install FLauncher on Firestick, Fire TV, and Android TV Box
Originally published at: How to Install FLauncher on Firestick, Fire TV, and Android TV Box
This step-by-step guide will show you How to Install FLauncher on Firestick, Fire TV, and Android TV Box. FLauncher is a custom launcher that users can install and integrate on various streaming devices to update their current user interface. If you are not a fan of the extensive ads and unwanted applications on your device,…
I have an old firestick 2nd generation, too old to install flauncher? I get parse error
There was a problem parsing the package. I’ve set it up on other firestick works great.
Advice?
If it’s a Fire OS 5 you may not be able to load the newer APKs. If flauncher has been around for some time you may be able to find an old apk to download and install that has the proper architecture .
Thx thought it may be the age of the stick
I installed it on another one I have and I like the set up that it only shows my apps
You can do the same with Wolf. You can hide any app icons you don’t want to see. I do that, then create folders for things like “Internet”, “Tools” “IPTV” and " Movies & TV". Makes for a simple and clean home page.
How do I reinstall FLauncher on onn box. Wife deleted it
Search Is Your Friend...!
